Anesthetic-induced transitions by propofol modeled by nonlocal neural populations involving two neuron types - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Biological Physics Année : 2008
Axel Hutt
Lutz Schimansky-Geier
  • Fonction : Auteur
The present work derives the spatiotemporal field equation of neural populations considering two types of neurons. The model considers pyramidal cells, which may excite or inhibit other neurons, and GABAergic interneurons inhibiting terminal neurons. Additionally, taking into account excitatory and inhibitory synapses, the neural population obeys a vector-field equation involving nonlocal spatial interactions. The work studies the effect of the anesthetic agent propofol, which increases the decay time of inhibitory synapses. In addition, it explains the bifurcation mechanism in some detail and finds a saddle–node bifurcation subject to the propofol concentration. This bifurcation may model the transition between consciousness and nonconsciousness and vice versa during the administration of general anesthetics in medicine.
inria-00332998 , version 1 (22-10-2008)
Axel Hutt, Lutz Schimansky-Geier. Anesthetic-induced transitions by propofol modeled by nonlocal neural populations involving two neuron types. Journal of Biological Physics, 2008, 34 (3-4), pp.433-440. ⟨10.1007/s10867-008-9065-4⟩. ⟨inria-00332998⟩
89 Consultations
0 Téléchargements
