Adaptive Probability-Based Broadcast Forwarding in Energy-Saving Sensor Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue ACM Transactions on Sensor Networks Année : 2008
Matthew J. Miller
  • Fonction : Auteur
  • PersonId : 854997
Indranil Gupta
  • Fonction : Auteur
  • PersonId : 832884
Networking protocols for multihop wireless sensor networks (WSNs) are required to simultaneously minimize resource usage as well as optimize performance metrics such as latency and reliability. This article explores the energy-latency-reliability tradeoff for broadcast in WSNs by presenting a new protocol called PBBF. Essentially, for a given reliability level, energy and latency are found to be inversely related and our study quantifies this relationship at the reliability boundary. Therefore, PBBF offers an application designer considerable flexibility in the choice of desired operation points. Furthermore, we propose an extension to dynamically adjust the PBBF parameters to minimize the input required from the designer.
pbbf-sengul-2.pdf (392.94 Ko) Télécharger le fichier
inria-00333703 , version 1 (04-11-2008)
  • HAL Id : inria-00333703 , version 1
Cigdem Sengul, Matthew J. Miller, Indranil Gupta. Adaptive Probability-Based Broadcast Forwarding in Energy-Saving Sensor Networks. ACM Transactions on Sensor Networks, 2008. ⟨inria-00333703⟩
119 Consultations
297 Téléchargements
