Invariant-based characterization of the relative position of two projective conics - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2008
In this paper, we give predicates of bidegree at most (6,6) in the input for characterizing the relative position of two projective conics. By relative position we mean the morphology of the intersection, the rigid isotopy class and which conic is inside the other when applicable. The predicates are derived by analyzing the algebraic invariant theory of pencils of conics and related constructions.
Fichier non déposé
inria-00335968 , version 1 (31-10-2008)
  • HAL Id : inria-00335968 , version 1
Sylvain Petitjean. Invariant-based characterization of the relative position of two projective conics. I. Emiris, F. Sottile, T. Theobald. Non-Linear Computational Geometry, Springer, 2008. ⟨inria-00335968⟩
245 Consultations
0 Téléchargements
