Implicit and Explicit Representations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Neural Networks Année : 2009
Nicolas P. Rougier
During the past decades, the symbol grounding problem, as it has been identified by Harnard, became a prominent problem in the cognitive science society. The idea that a symbol was much more than a mere meaningless token that can be processed through some algorithm, sheds a new light on higher brain functions such as language and cognition. We present in this article a computational framework that may help our understanding of the nature of grounded representations. Two models are briefly introduced that aim at emphasizing the difference we make between implicit and explicit representations.
Rougier.pdf (306.68 Ko) Télécharger le fichier
inria-00336167 , version 1 (07-01-2009)
Nicolas P. Rougier. Implicit and Explicit Representations. Neural Networks, 2009, 22 (2), pp.155-160. ⟨10.1016/j.neunet.2009.01.00⟩. ⟨inria-00336167⟩
104 Consultations
4070 Téléchargements
