Power-Aware Real-Time Scheduling upon Identical Multiprocessor Platforms - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
Vincent Nélis
  • Fonction : Auteur
  • PersonId : 855184
Joël Goossens
  • Fonction : Auteur
  • PersonId : 830909
Raymond Devillers
  • Fonction : Auteur
  • PersonId : 855185
Dragomir Milojevic
  • Fonction : Auteur
  • PersonId : 855186
In this paper, we address the power-aware scheduling of sporadic constrained-deadline hard real-time tasks using dynamic voltage scaling upon multiprocessor platforms. We propose two distinct algorithms. Our first algorithm is an off-line speed determination mechanism which provides an identical speed for each processor. That speed guarantees that all deadlines are met if the jobs are scheduled using EDF. The second algorithm is an on-line and adaptive speed adjustment mechanism which reduces the energy consumption while the system is running.
SUTC2008.pdf (295.57 Ko) Télécharger le fichier
inria-00336172 , version 1 (03-11-2008)
Vincent Nélis, Joël Goossens, Raymond Devillers, Dragomir Milojevic, Nicolas Navet. Power-Aware Real-Time Scheduling upon Identical Multiprocessor Platforms. 2008 IEEE International Conference on Sensor Networks, Ubiquitous, and Trustworthy Computing, Jun 2008, Taichung, Taiwan. pp.209-216, ⟨10.1109/SUTC.2008.31⟩. ⟨inria-00336172⟩
145 Consultations
203 Téléchargements
