Improvement of Reduced Order Modeling based on Proper Orthogonal Decomposition - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
This study focuses on stabilizing Reduced Order Model based on Proper Orthogonal Decomposition (POD) and on improving the POD functional subspace. A modified reduced order model (ROM) that incorporates directly the pressure term is proposed. The ROM is obtained by seeking a solution that lives in the POD subspace and at the same time minimizes the Navier-Stokes residuals. Both ROM stabilization and POD subspace adaptation make use of methods based on the fine scale equation that is approximated using the residuals of the Navier-Sokes equations. Results are shown for the 2D confined cylinder wake flow.
ICCFD5.pdf (1.66 Mo) Télécharger le fichier
inria-00336177 , version 1 (03-11-2008)
  • HAL Id : inria-00336177 , version 1
Michel Bergmann, Charles-Henri Bruneau, Angelo Iollo. Improvement of Reduced Order Modeling based on Proper Orthogonal Decomposition. The Fifth International Conference on Computational Fluid Dynamics, Jul 2008, Séoul, South Korea. ⟨inria-00336177⟩
199 Consultations
88 Téléchargements
