Solipsis: A Decentralized Architecture for Virtual Environments - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
Lack of scalability is a key issue for virtual-environment technology, and more generally for any large-scale online experience because it prevents the emergence of a truly massive virtual-world infrastructure (Metaverse). The Solipsis project tackles this issue through the use of peer-to-peer technology, and makes it possible to build and manage a world-scale Metaverse in a truly distributed manner. Following a peer-to-peer scheme, entities collaborate to build up a common set of virtual worlds. In this paper, we present a first draft of the \sol architecture as well as the communication protocol used to share data between peers. The protocol is based on Raynet, an n-dimensional Voronoi-based overlay network. Its data-dissemination policy takes advantage of the view-depedent representation of 3D contents. Moreover, the protocol effectively distributes the execution of computationally intensive tasks that are usually executed on the server-side, such as collision detection and physics computation. Finally, we also present our web component, a 3D navigator that can easily run on terminals with scarce resources, and that provides solutions for smooth transitions between 3D Web and Web 2.0.
MMVE.pdf (209.86 Ko) Télécharger le fichier
inria-00337057 , version 1 (05-11-2008)
  • HAL Id : inria-00337057 , version 1
Davide Frey, Jérôme Royan, Romain Piegay, Anne-Marie Kermarrec, Emmanuelle Anceaume, et al.. Solipsis: A Decentralized Architecture for Virtual Environments. 1st International Workshop on Massively Multiuser Virtual Environments, Mar 2008, Reno, NV, United States. ⟨inria-00337057⟩
2431 Consultations
2386 Téléchargements
