Random Forests: some methodological insights - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2008
This paper examines from an experimental perspective random forests, the increasingly used statistical method for classification and regression problems introduced by Leo Breiman in 2001. It first aims at confirming, known but sparse, advice for using random forests and at proposing some complementary remarks for both standard problems as well as high dimensional ones for which the number of variables hugely exceeds the sample size. But the main contribution of this paper is twofold: to provide some insights about the behavior of the variable importance index based on random forests and in addition, to propose to investigate two classical issues of variable selection. The first one is to find important variables for interpretation and the second one is more restrictive and try to design a good prediction model. The strategy involves a ranking of explanatory variables using the random forests score of importance and a stepwise ascending variable introduction strategy.
RR-6729.pdf (452.14 Ko) Télécharger le fichier
inria-00340725 , version 1 (21-11-2008)
  • HAL Id : inria-00340725 , version 1
  • ARXIV : 0811.3619
Robin Genuer, Jean-Michel Poggi, Christine Tuleau. Random Forests: some methodological insights. [Research Report] RR-6729, INRIA. 2008. ⟨inria-00340725⟩
797 Consultations
790 Téléchargements
