Fusion and fission of genes define a metric between fungal genomes. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue PLoS Computational Biology Année : 2008
Gene fusion and fission events are key mechanisms in the evolution of gene architecture, whose effects are visible in protein architecture when they occur in coding sequences. Until now, the detection of fusion and fission events has been performed at the level of protein sequences with a post facto removal of supernumerary links due to paralogy, and often did not include looking for events defined only in single genomes. We propose a method for the detection of these events, defined on groups of paralogs to compensate for the gene redundancy of eukaryotic genomes, and apply it to the proteomes of 12 fungal species. We collected an inventory of 1,680 elementary fusion and fission events. In half the cases, both composite and element genes are found in the same species. Per-species counts of events correlate with the species genome size, suggesting a random mechanism of occurrence. Some biological functions of the genes involved in fusion and fission events are slightly over- or under-represented. As already noted in previous studies, the genes involved in an event tend to belong to the same functional category. We inferred the position of each event in the evolution tree of the 12 fungal species. The event localization counts for all the segments of the tree provide a metric that depicts the "recombinational" phylogeny among fungi. A possible interpretation of this metric as distance in adaptation space is proposed.
inria-00341569 , version 1 (25-11-2008)
Pascal Durrens, Macha Nikolski, David James Sherman. Fusion and fission of genes define a metric between fungal genomes.. PLoS Computational Biology, 2008, 4 (10), pp.e1000200. ⟨10.1371/journal.pcbi.1000200⟩. ⟨inria-00341569⟩
107 Consultations
0 Téléchargements
Gmail Mastodon Facebook X LinkedIn More
