MAI: Memory Affinity Interface - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport Technique) Année : 2008
In this document, we describe an interface called MAI. This interface allows developers to manage memory affinity in NUMA architectures. The affinity unit in MAI is an array of the parallel application. A set of memory policies implemented in MAI can be applied to these arrays in a simple way. High-level functions implemented in MAI minimize developers work when managing memory affinity in NUMA machines. MAI's performance has been evaluating on two different NUMA machines using some parallel applications. Results obtained with MAI present important gains when compared with the standard memory affinity solutions.
RT-0359.pdf (1.05 Mo) Télécharger le fichier
inria-00344189 , version 1 (04-12-2008)
inria-00344189 , version 2 (30-03-2009)
inria-00344189 , version 3 (29-09-2009)
inria-00344189 , version 4 (28-11-2009)
inria-00344189 , version 5 (30-11-2009)
inria-00344189 , version 6 (14-06-2010)
  • HAL Id : inria-00344189 , version 2
Christiane Pousa Ribeiro, Jean-François Méhaut. MAI: Memory Affinity Interface. [Technical Report] RT-0359, 2008. ⟨inria-00344189v2⟩
Collections
INRIA-RRRT
172 Consultations
264 Téléchargements
