FPG: A code generator for fast and certified geometric predicates - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
Sylvain Pion
We present a general purpose code analyzer and generator for filtered predicates, which are critical for geometric algorithms. While there already exist such code generators, our contribution is to generate ”almost static filters”, a type of filter which could not be generated previously. The generated and safe filtered predicates are almost as fast as their inexact floating point counterparts, in most cases.
FPG_RNC8.pdf (150.82 Ko) Télécharger le fichier
inria-00344297 , version 1 (04-12-2008)
  • HAL Id : inria-00344297 , version 1
Andreas Meyer, Sylvain Pion. FPG: A code generator for fast and certified geometric predicates. Real Numbers and Computers, Jun 2008, Santiago de Compostela, Spain. pp.47-60. ⟨inria-00344297⟩
Collections
INRIA INRIA2
704 Consultations
973 Téléchargements
