Numerical methods for low-order modeling of fluid flows based on POD - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2008
This report explores some numerical alternatives that can be exploited to derive efficient low-order models of the Navier-Stokes equations. It is shown that an optimal solution sampling can be derived using appropriate norms of the Navier-Stokes residuals. Then the classical Galerkin approach is derived in the context of a residual minimization method that is similar to variational multiscale modeling. Finally, calibration techniques are reviewed and applied to the computation of unsteady aerodynamic forces. Examples pertaining to both non-actuated and actuated flows are shown.
RR-6758.pdf (1.9 Mo) Télécharger le fichier
inria-00345184 , version 1 (08-12-2008)
  • HAL Id : inria-00345184 , version 1
Jessie Weller, Edoardo Lombardi, Michel Bergmann, Angelo Iollo. Numerical methods for low-order modeling of fluid flows based on POD. [Research Report] RR-6758, INRIA. 2008, pp.23. ⟨inria-00345184⟩
113 Consultations
631 Téléchargements
