Occlusion Textures for Plausible Soft Shadows - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Computer Graphics Forum Année : 2008
This paper presents a new approach to compute plausible soft shadows for complex dynamic scenes and rectangular light sources. We estimate the occlusion at each point of the scene using prefiltered occlusion textures, which dynamically approximate the scene geometry. The algorithm is fast and its performance independent of the light's size. Being image-based, it is mostly independent of the scene complexity and type. No a priori information is needed, and there is no caster/receiver separation. This makes the method appealing and easy to use.
Mots clés
pib06.pdf (1.06 Mo) Télécharger le fichier
video2-pib06.avi (19.06 Mo) Télécharger le fichier
Format : Figure, Image
Format : Vidéo
inria-00345281 , version 1 (09-07-2010)
Elmar Eisemann, Xavier Décoret. Occlusion Textures for Plausible Soft Shadows. Computer Graphics Forum, 2008, 27 (1), pp.13-23. ⟨10.1111/j.1467-8659.2007.01037.x⟩. ⟨inria-00345281⟩
171 Consultations
428 Téléchargements
