Sample-based Visibility for Soft Shadows Using Alias-free Shadow Maps - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Computer Graphics Forum Année : 2008
This paper introduces an accurate real-time soft shadow algorithm that uses sample based visibility. Initially, we present a GPU-based alias-free hard shadow map algorithm that typically requires only a single render pass from the light, in contrast to using depth peeling and one pass per layer. For closed objects, we also suppress the need for a bias. The method is extended to soft shadow sampling for an arbitrarily shaped area-/volumetric light source using 128-1024 light samples per screen pixel. The alias-free shadow map guarantees that the visibility is accurately sampled per screen-space pixel, even for arbitrarily shaped (e.g. non-planar) surfaces or solid objects. Another contribution is a smooth coherent shading model to avoid common light leakage near shadow borders due to normal interpolation. More at http://artis.imag.fr/Publications/2008/SEA08
Mots clés
softshadows2008EGSR.pdf (3.14 Mo) Télécharger le fichier
Format : Figure, Image
inria-00345285 , version 1 (08-12-2008)
Erik Sintorn, Elmar Eisemann, Ulf Assarsson. Sample-based Visibility for Soft Shadows Using Alias-free Shadow Maps. Computer Graphics Forum, 2008, Proceedings of the Eurographics Symposium on Rendering 2008, 27 (4), pp.1285-1292. ⟨10.1111/j.1467-8659.2008.01267.x⟩. ⟨inria-00345285⟩
303 Consultations
638 Téléchargements
