Stylized Vector Art from 3D Models with Region Support - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Computer Graphics Forum Année : 2008
We describe a rendering system that converts a 3D meshed model into the stylized 2D filled-region vector-art commonly found in clip-art libraries. To properly define filled regions, we analyze and combine accurate but jagged face-normal contours with smooth but inaccurate interpolated vertex normal contours, and construct a new smooth shadow contour that properly surrounds the actual jagged shadow contour. We decompose region definition into geometric and topological components, using machine precision for geometry processing and raster-precision to accelerate topological queries. We extend programmable stylization to simplify, smooth and stylize filled regions. The result renders 10K-face meshes into custom clip-art in seconds.
clipartmesh.pdf (7.95 Mo) Télécharger le fichier
Format : Figure, Image
inria-00345295 , version 1 (08-12-2008)
Elmar Eisemann, Holger Winnenmöller, John C. Hart, David Salesin. Stylized Vector Art from 3D Models with Region Support. Computer Graphics Forum, 2008, Special Issue: Proceedings of the 19th Eurographics Symposium on Rendering 2008, 27 (4), pp.1199--1207. ⟨10.1111/j.1467-8659.2008.01258.x⟩. ⟨inria-00345295⟩
525 Consultations
577 Téléchargements
