Concurrent Scheduling of Parallel Task Graphs on Multi-Clusters Using Constrained Resource Allocations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2008
Scheduling multiple applications on heterogeneous multi-clusters is challenging as the different applications have to compete to access the resources. A scheduler thus has to ensure a fair distribution of the resources among the applications and prevent harmful selfish behaviors while still trying to minimize their respective completion time. In this study we consider mixed-parallel applications, represented by graphs whose nodes are data-parallel tasks, that are scheduled in two steps: allocation and mapping. We investigate several strategies to constrain the amount of resources the scheduler can allocate to each submitted application. This study is then evaluated over a wide range of scenarios.
RR-6774.pdf (325.05 Ko) Télécharger le fichier
inria-00347203 , version 1 (15-12-2008)
  • HAL Id : inria-00347203 , version 1
Tchimou N'Takpé, Frédéric Suter. Concurrent Scheduling of Parallel Task Graphs on Multi-Clusters Using Constrained Resource Allocations. [Research Report] RR-6774, INRIA. 2008, pp.19. ⟨inria-00347203⟩
139 Consultations
284 Téléchargements
