Parallel Reconfigurable Operator for Genomic Sequence Comparison: Architecture and Performance Analyses - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2008
This document describes a parallel genomic sequence comparison operator for reconfigurable platforms. It has been implemented for speeding up the time consuming parts of the IRISA-TBLASTN program designed for comparing full genomes with large protein banks. Speed-up ranging from 25 to 200 has been measured on real genomic data.
RR-6776.pdf (317.7 Ko) Télécharger le fichier
inria-00348482 , version 1 (23-12-2008)
  • HAL Id : inria-00348482 , version 1
Alexandre Cornu, Francois Dussaugey, Dominique Lavenier. Parallel Reconfigurable Operator for Genomic Sequence Comparison: Architecture and Performance Analyses. [Research Report] RR-6776, INRIA. 2008. ⟨inria-00348482⟩
98 Consultations
116 Téléchargements
