s'authentifier
version française rss feed
inria-00348711, version 1
The Boost Interval Arithmetic Library
Hervé Brönnimann () a1, Guillaume Melquiond () b2, Sylvain Pion () 34
Real Numbers and Computers (2003) 65-80
Résumé : We report on the design of the Boost interval arithmetic library, a C++ library designed to efficiently handle mathematical intervals in a generic way. The design of the library is unique in that it uses policies to specify the variable behaviors: rounding, checking, comparisons. As a result, with the proper policies, our interval library is able to emulate almost any of the specialized libraries available for interval arithmetic. This library is openly available at http://www.boost.org/ . Using this library, we then examine interval-based filters to compute the sign of a determinant, proposed by Burnikel and two authors of the library, and revisit and extend their experiments. We also illustrate other uses of the library.
  • Domaine : Informatique/Arithmétique des ordinateurs
    Informatique/Génie logiciel
  • Mots-clés : Interval arithmetic – library – generic programming – policy-based design – determinant sign – filter
  • inria-00348711, version 1
  • oai:hal.inria.fr:inria-00348711
  • Contributeur :
  • Soumis le : Samedi 20 Décembre 2008, 20:01:43
  • Dernière modification le : Mercredi 11 Février 2009, 16:11:38
tous les articles de la base du CCSd...
