The Boost Interval Arithmetic Library - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2003
We report on the design of the Boost interval arithmetic library, a C++ library designed to efficiently handle mathematical intervals in a generic way. The design of the library is unique in that it uses policies to specify the variable behaviors: rounding, checking, comparisons. As a result, with the proper policies, our interval library is able to emulate almost any of the specialized libraries available for interval arithmetic. This library is openly available at http://www.boost.org/ . Using this library, we then examine interval-based filters to compute the sign of a determinant, proposed by Burnikel and two authors of the library, and revisit and extend their experiments. We also illustrate other uses of the library.
rnc.pdf (158.1 Ko) Télécharger le fichier
inria-00348711 , version 1 (20-12-2008)
  • HAL Id : inria-00348711 , version 1
Hervé Brönnimann, Guillaume Melquiond, Sylvain Pion. The Boost Interval Arithmetic Library. Real Numbers and Computers, 2003, Lyon, France. pp.65-80. ⟨inria-00348711⟩
698 Consultations
920 Téléchargements
