Visual servo control, Part I: Basic approaches - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Robotics and Automation Magazine Année : 2006
This article is the first of a two-part series on the topic of visual servo control: using computer vision data in the servo loop to control the motion of a robot. In the present article, we describe the basic techniques that are by now well established in the field. We first give a general overview of the formulation of the visual servo control problem. We then describe the two archetypal visual servo control schemes: image-based and position-based visual servo control. Finally, we discuss performance and stability issues that pertain to these two schemes, motivating the second article in the series, in which we consider advanced techniques.
2006_ieee_ram_chaumette.pdf (706.18 Ko) Télécharger le fichier
inria-00350283 , version 1 (06-01-2009)
  • HAL Id : inria-00350283 , version 1
François Chaumette, S. Hutchinson. Visual servo control, Part I: Basic approaches. IEEE Robotics and Automation Magazine, 2006, 13 (4), pp.82-90. ⟨inria-00350283⟩
2126 Consultations
13914 Téléchargements
