Statistically robust 2D visual servoing
A fundamental step towards broadening the use of real world image-based visual servoing is to deal with the important issue of reliability and robustness. In order to address this issue, a closed loop control law is proposed that simultaneously accomplishes a visual servoing task and is robust to a general class of image processing errors. This is achieved with the application of widely accepted statistical techniques such as robust M-estimation and LMedS. Experimental results are presented which demonstrate visual servoing tasks that resist severe outlier contamination.
Domains
Robotics [cs.RO]
