Visual servo control, Part II: Advanced approaches - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Robotics and Automation Magazine Année : 2007
This article is the second of a two-part tutorial on visual servo control. In this tutorial, we have only considered velocity controllers. It is convenient for most of classical robot arms. However, the dynamics of the robot must of course be taken into account for high speed task, or when we deal with mobile nonholonomic or underactuated robots. As for the sensor, geometrical features coming from a classical perspective camera is considered. Features related to the image motion or coming from other vision sensors necessitate to revisit the modeling issues to select adequate visual features. Finally, fusing visual features with data coming from other sensors at the level of the control scheme will allow to address new research topics.
2007_ieee_ram_chaumette.pdf (381.49 Ko) Télécharger le fichier
inria-00350638 , version 1 (07-01-2009)
  • HAL Id : inria-00350638 , version 1
François Chaumette, S. Hutchinson. Visual servo control, Part II: Advanced approaches. IEEE Robotics and Automation Magazine, 2007, 14 (1), pp.109-118. ⟨inria-00350638⟩
1827 Consultations
6562 Téléchargements
