Catadioptric visual servoing from 3D straight lines - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Robotics Année : 2008
In this paper, we consider the problem of controlling a 6 DOF holonomic robot and a nonholonomic mobile robot from the projection of 3-D straight lines in the image plane of central catadioptric systems. A generic central catadioptric interaction matrix for the projection of 3-D straight lines is derived using an unifying imaging model valid for an entire class of cameras. This result is exploited to design an image-based control law that allows us to control the 6 DOF of a robotic arm. Then, the projected lines are exploited to control a nonholonomic robot. We show that as when considering a robotic arm, the control objectives are mainly based on catadioptric image feature and that local asymptotic con- vergence is guaranteed. Simulation results and real experiments with a 6 DOF eye-to-hand system and a mobile robot illustrate the control strategy.
2008_itro_hadj.pdf (1.6 Mo) Télécharger le fichier
inria-00351865 , version 1 (12-01-2009)
  • HAL Id : inria-00351865 , version 1
Hicham Hadj-Abdelkader, Youcef Mezouar, P. Martinet, François Chaumette. Catadioptric visual servoing from 3D straight lines. IEEE Transactions on Robotics, 2008, 24 (3), pp.652-665. ⟨inria-00351865⟩
216 Consultations
223 Téléchargements
