Hybrid tracking approach using optical flow and pose estimation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
This paper proposes an hybrid approach to estimate the 3D pose of an object. The integration of texture information based on image intensities in a more classical non-linear edge-based pose estimation computation has proven to highly increase the reliability of the tracker. We propose in this work to exploit the data provided by an optical flow algorithm for a similar purpose. The advantage of using the optical flow is that it does not require any a priori knowledge on the object appearance. The registration of 2D and 3D cues for monocular tracking is performed by a non linear minimization. Results obtained show that using optical flow enables to perform robust 3D hybrid tracking even without any texture model
2008_icip_pressigout.pdf (274.67 Ko) Télécharger le fichier
inria-00351874 , version 1 (12-01-2009)
  • HAL Id : inria-00351874 , version 1
Muriel Pressigout, Eric Marchand, Etienne Mémin. Hybrid tracking approach using optical flow and pose estimation. IEEE Int. Conf. on Image Processing, ICIP'08, 2008, San Diego, California, France. ⟨inria-00351874⟩
328 Consultations
433 Téléchargements
