Using spherical moments for visual servoing from a special target with unique projection center cameras - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
This paper focuses on visual servoing from a special target using a vision sensor with an unique projection center. The target is a sphere marked with two points on its surface. Using a spherical projection model, a new minimal set of six features is proposed for this target. Spherical moments are exploited to compute the new set on the image of the sensor. Using the new set, a classical control method is proved to be asymptotically stable even in the presence of modeling errors. Experimental results with a perspective camera and a fish-eye camera validate the proposed theoretical results.
2008_icarcv_tatsambon.pdf (294.33 Ko) Télécharger le fichier
inria-00351879 , version 1 (12-01-2009)
  • HAL Id : inria-00351879 , version 1
R. Tatsambon Fomena, François Chaumette. Using spherical moments for visual servoing from a special target with unique projection center cameras. Int. Conf. on Control, Automation, Robotics and Vision, ICARCV 2008, 2008, Hanoi, France. pp.119-124. ⟨inria-00351879⟩
172 Consultations
116 Téléchargements
