An efficient method to compute the inverse Jacobian matrix in visual servoing - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2004
The paper presents a method for estimating the inverse Jacobian matrix of a function, without computing the direct Jacobian matrix. The resulting inverse Jacobian matrix is shown to perform much better in modelling a relation $\theta= f^{-1}(x)$ than the classical Moore-Penrose inverse $J^+_f$ . Theoretical insight as well as comparisons in the domain of visual servoing are provided to demonstrate this assertion.
2004_icra_lapreste.pdf (139 Ko) Télécharger le fichier
inria-00352026 , version 1 (12-01-2009)
  • HAL Id : inria-00352026 , version 1
Jean-Thierry Lapresté, Frédéric Jurie, Michel Dhome, François Chaumette. An efficient method to compute the inverse Jacobian matrix in visual servoing. IEEE Int. Conf. on Robotics and Automation, ICRA'04, 2004, New Orleans, Louisiana, France. pp.727-732. ⟨inria-00352026⟩
372 Consultations
796 Téléchargements
