Multi-cameras visual servoing - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2000
E. Malis
S. Boudet
  • Fonction : Auteur
EDF
In this paper, the classical visual servoing techniques have been extended to the use of several cameras observing different parts of an object. The multi-cameras visual servoing has been designed as a part of the task function approach. The particular choice of the task function allows us to simplify the design of the control law and the stability analysis. A positioning task on a cumbersome object has been realized using 2D and 2 1/2D visual servoing with two cameras, mounted on a manipulator robot and observing two different parts of the object.
Mots clés
2000_icra_malis.pdf (323.93 Ko) Télécharger le fichier
inria-00352160 , version 1 (12-01-2009)
  • HAL Id : inria-00352160 , version 1
E. Malis, François Chaumette, S. Boudet. Multi-cameras visual servoing. IEEE Int. Conf. on Robotics and Automation, ICRA'00, 2000, San Francisco, California, United States. pp.3183-3188. ⟨inria-00352160⟩
186 Consultations
409 Téléchargements
