Visual tracking by coupling 2D motion and 3D pose estimation. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 1999
Patrick Bouthemy
  • Fonction : Auteur
  • PersonId : 830256
V. Moreau
  • Fonction : Auteur
EDF
We present an original method for tracking in an image sequence complex objects which can be modeled approximately by a polyhedral shape. The approach relies on the estimation of the object image motion as well as the computation of the object pose. The proposed method fulfills real-time constraints along with reliability and robustness requirements.
Mots clés
1999_icip_marchand.pdf (1.15 Mo) Télécharger le fichier
Origine Fichiers éditeurs autorisés sur une archive ouverte
inria-00352548 , version 1 (13-01-2009)
  • HAL Id : inria-00352548 , version 1
E. Marchand, Patrick Bouthemy, François Chaumette, V. Moreau. Visual tracking by coupling 2D motion and 3D pose estimation.. IEEE Int Conf. on Image Processing, ICIP'99, 1999, Kobe, Japan, Japan. pp.98-102. ⟨inria-00352548⟩
171 Consultations
117 Téléchargements
Gmail Mastodon Facebook X LinkedIn More
