Polynomial Wavelet Trees for Bidirectional Texture Functions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
Polynomial Wavelet Tree is a new tool for accurate and efficient compression of BTFs. The key idea is to separate directional and spatial variations by projecting the spatial BTF domain (i.e., the light-dependent textures) onto a wavelet basis and to approximate these light-dependent wavelet coefficients with a polynomial function. Fitting wavelet coefficients instead of data themselves is a more efficient approximation compared to previous solutions since low frequency light transitions are smooth and higher frequency coefficients can be quantized with less importance. This wavelet projection and the light-dependent polynomial approximation is done for each view-point. Our solution is also designed for efficient high quality materials rendering on GPU.
PWT.pdf (88.6 Ko) Télécharger le fichier
inria-00355359 , version 1 (22-01-2009)
Jerome Baril, Tamy Boubekeur, Patrick Gioia, Christophe Schlick. Polynomial Wavelet Trees for Bidirectional Texture Functions. ACM Siggraph 2008 - Talk Program, Aug 2008, Los Angeles, United States. ⟨10.1145/1401032.1401072⟩. ⟨inria-00355359⟩
108 Consultations
141 Téléchargements
