Multi-Hop Wireless Networking with OSPF: MPR-based Routing Extensions for MANETs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2009
Incorporating multi-hop wireless networks in the IP infrastructure is an effort to which a growing community participates. One instance of such activity is the extension of the routing protocol OSPF, for operation on MANETs. Such extension allows OSPF, the most widely deployed interior gateway routing protocol on the Internet, to work on heterogeneous networks encompassing both wired and wireless routers. The latter may self-organize as multi-hop wireless subnetworks, and may be mobile. Three solutions have been proposed for this extension, among which two based on techniques derived from multi-point relaying (MPR) techniques and OLSR. This paper analyzes these two approaches and identifies some fundamental discussion items that pertain to adapting OSPF mechanisms to multi-hop wireless networking, before concluding with a proposal for a unique, merged solution based on this analysis.
RR-6822.pdf (384.62 Ko) Télécharger le fichier
inria-00357952 , version 1 (02-02-2009)
  • HAL Id : inria-00357952 , version 1
Emmanuel Baccelli, Juan Antonio Cordero Fuertes, Philippe Jacquet. Multi-Hop Wireless Networking with OSPF: MPR-based Routing Extensions for MANETs. [Research Report] RR-6822, INRIA. 2009, pp.25. ⟨inria-00357952⟩
185 Consultations
240 Téléchargements
