Interleaving Delaunay Refinement and Optimization for Practical Isotropic Tetrahedron Mesh Generation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2009
Jane Tournois
  • Fonction : Auteur
  • PersonId : 857875
Pierre Alliez
Mathieu Desbrun
We present a practical approach to isotropic tetrahedral meshing of 3D domains bounded by piecewise smooth surfaces. Building upon recent theoretical and practical advances, our algorithm interleaves Delaunay refinement and mesh optimization to generate quality meshes that satisfy a set of user-defined criteria. This interleaving is shown to be more sparing in Steiner points' insertions than refinement alone, and to produce higher quality meshes than optimization alone. A careful treatment of boundaries and their features is presented, offering a versatile framework for designing smoothly graded tetrahedral meshes of complex geometries.
RR-6826.pdf (20.37 Mo) Télécharger le fichier
inria-00359288 , version 1 (06-02-2009)
  • HAL Id : inria-00359288 , version 1
Jane Tournois, Camille Wormser, Pierre Alliez, Mathieu Desbrun. Interleaving Delaunay Refinement and Optimization for Practical Isotropic Tetrahedron Mesh Generation. [Research Report] RR-6826, INRIA. 2009, pp.27. ⟨inria-00359288⟩
465 Consultations
268 Téléchargements
