A formally verified compiler back-end - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Automated Reasoning Année : 2009
This article describes the development and formal verification (proof of semantic preservation) of a compiler back-end from Cminor (a simple imperative intermediate language) to PowerPC assembly code, using the Coq proof assistant both for programming the compiler and for proving its correctness. Such a verified compiler is useful in the context of formal methods applied to the certification of critical software: the verification of the compiler guarantees that the safety properties proved on the source code hold for the executable compiled code as well.
paper2.pdf (701.25 Ko) Télécharger le fichier
inria-00360768 , version 1 (11-02-2009)
inria-00360768 , version 2 (21-07-2009)
inria-00360768 , version 3 (14-11-2009)
Xavier Leroy. A formally verified compiler back-end. Journal of Automated Reasoning, 2009, 43 (4), pp.363-446. ⟨10.1007/s10817-009-9155-4⟩. ⟨inria-00360768v3⟩
Collections
INRIA INRIA2 ANR
479 Consultations
826 Téléchargements
