A Utility-based Framework for Assessing Fairness Schemes in Ad-Hoc Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2009
Fairness in multihop ad hoc networks has received considerable attention in the literature. A plethora of protocols have been proposed, which compute the ``optimal'' bit rates of the transmitting mobile nodes over short time-scales so that a certain fairness criterion is met. However, there has been limited research on the impact of the varying short-term allocations of these protocols due to nodes mobility on the user-perceived QoS (and social welfare) for services of long duration. In this paper, we introduce a utility-based framework, based on {\em QoS-aware history-dependent} utility functions. These functions quantify the satisfaction that the users of the MANETs obtain from the way their long-lived service sessions are allocated bandwidth, due to the behavior of the fairness protocols proposed for ad hoc networks. Finally, we demonstrate the framework's usefulness, by performing a comparative assessment of the fairness protocol of our previous work with the standard IEEE 802.11.
RR-6843.pdf (467.46 Ko) Télécharger le fichier
inria-00360848 , version 1 (12-02-2009)
inria-00360848 , version 2 (17-02-2009)
  • HAL Id : inria-00360848 , version 2
Emmanouil Dramitinos, Rémi Vannier, Isabelle Guérin-Lassous. A Utility-based Framework for Assessing Fairness Schemes in Ad-Hoc Networks. [Research Report] RR-6843, INRIA. 2009, pp.15. ⟨inria-00360848v2⟩
140 Consultations
108 Téléchargements
