Vector field regularization by generalized diffusion - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2009
Regularization is a common procedure when dealing with inverse problems. Because of the ill-posedness of many inverse problems, one needs to add some constraints as regularization to the problem in order to get a satisfactory solution. A difficulty when using multiple constraints is to properly choose a weighting parameter for each constraint. We propose here a vector field regularization method that combines in a single constraint the two well-known regularization methods namely Tikhonov regularization and smoothing regularization. The particularity of this new method is that one have only one balance parameter to determine. We also suggest a robust implementation of the proposed method based on the equivalent generalized diffusion equation in some particular cases. This implementation is illustrated on a set of vector fields of fluid motion
RR-6844.pdf (725.32 Ko) Télécharger le fichier
inria-00360904 , version 1 (12-02-2009)
inria-00360904 , version 2 (13-02-2009)
  • HAL Id : inria-00360904 , version 1
Innocent Souopgui, François-Xavier Le Dimet, Arthur Vidard. Vector field regularization by generalized diffusion. [Research Report] RR-6844, 2009, pp.20. ⟨inria-00360904v1⟩
Collections
INRIA-RRRT
228 Consultations
369 Téléchargements
