Directed binary hierarchies and directed ultrametrics - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2009
Directed binary hierarchies have been introduced in order to give a graphical reduced representation of a family of association rules. This type of structure extends in a very specific way that underlying binary hierarchical classification. In this paper an accurate formalization of this new structure is studied. A binary directed hierarchy is defined as a set of ordered pairs of subsets of the initial individual set satisfying specific conditions. New notion of directed ultrametricity is studied. The main result consists of establishing a bijective correspondence between a directed ultrametric space and a directed binary hierarchy. Moreover, an algorithm is proposed in order to transform a directed ultrametric structure into a graphical representation associated with a directed binary hierarchy.
RR-6815-v2.pdf (261.61 Ko) Télécharger le fichier
inria-00361727 , version 1 (16-02-2009)
inria-00361727 , version 2 (26-02-2009)
  • HAL Id : inria-00361727 , version 2
Israël-César Lerman, Pascale Kuntz. Directed binary hierarchies and directed ultrametrics. [Research Report] RR-6815, INRIA. 2009, pp.27. ⟨inria-00361727v2⟩
193 Consultations
152 Téléchargements
