inria-00362883, version 1
Stroke Pattern Analysis and Synthesis
Pascal Barla
a, 1Simon Breslav 2Joëlle Thollot
b, 1François X. Sillion
a, 1Lee Markosian 2
Proc. of Eurographics 2006 : Computer Graphics Forum 25 (2006)
Résumé : We present a synthesis technique that can automatically generate stroke patterns based on a user-specified reference pattern. Our method is an extension of texture synthesis techniques to vector-based patterns. Such an extension requires (a) an analysis of the pattern properties to extract meaningful pattern elements (defined as clusters of strokes) and (b) a synthesis algorithm based on similarities in the detected stroke clusters. Our method is based on results from human vision research concerning perceptual organization. The resulting synthesized patterns effectively reproduce the properties of the input patterns, and can be used to fill both 1D paths and 2D regions.
- a – INRIA
- b – Grenoble INP
- 1 : ARTIS (IMAG-INRIA Rhône-Alpes / GRAVIR)
- CNRS : FR71 – CNRS : UMR5527 – INRIA – Université Joseph Fourier - Grenoble I – Institut National Polytechnique de Grenoble (INPG)
- 2 : Department of Electrical Engineering and Computer Science (EECS)
- University of Michigan
- Domaine : Informatique/Synthèse d'image et réalité virtuelle
- inria-00362883, version 1
- http://hal.inria.fr/inria-00362883
- oai:hal.inria.fr:inria-00362883
- Contributeur : Pascal Barla
- Soumis le : Vendredi 29 Avril 2011, 11:47:57
- Dernière modification le : Jeudi 12 Mai 2011, 15:30:52
Documents associés
Exporter
