Stroke Pattern Analysis and Synthesis - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2006
We present a synthesis technique that can automatically generate stroke patterns based on a user-specified reference pattern. Our method is an extension of texture synthesis techniques to vector-based patterns. Such an extension requires (a) an analysis of the pattern properties to extract meaningful pattern elements (defined as clusters of strokes) and (b) a synthesis algorithm based on similarities in the detected stroke clusters. Our method is based on results from human vision research concerning perceptual organization. The resulting synthesized patterns effectively reproduce the properties of the input patterns, and can be used to fill both 1D paths and 2D regions.
pattern.pdf (510.43 Ko) Télécharger le fichier
Format : Figure, Image
inria-00362883 , version 1 (29-04-2011)
  • HAL Id : inria-00362883 , version 1
Pascal Barla, Simon Breslav, Joëlle Thollot, François X. Sillion, Lee Markosian. Stroke Pattern Analysis and Synthesis. Proc. of Eurographics 2006 : Computer Graphics Forum, Sep 2006, Vienna, Austria. ⟨inria-00362883⟩
564 Consultations
1727 Téléchargements
