Synthesis of Non-Interferent Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
In this paper, we focus on distributed systems sub ject to security issues. Such systems are usually composed of two entities: a high level user and a low level user that can both do some actions. The security properties we consider are non-interference properties. A system is non-interferent if the low level user cannot deduce any information by playing its low level actions. Various notions of non-interference have been defined in the literature, and in this paper we focus on two of them: one trace-based property (SNNI) and another bisimulation-based property (BSNNI). For these properties we study the problems of synthesis of a high level user so that the system is non-interferent. We prove that a most permissive high level user can be computed when one exists.
Autre [cs.OH]
mmm-07.pdf (175.52 Ko) Télécharger le fichier
inria-00363029 , version 1 (20-02-2009)
  • HAL Id : inria-00363029 , version 1
Franck Cassez, John Mullins, Olivier Henri Roux. Synthesis of Non-Interferent Systems. 4th Int. Conf. on Mathematical Methods, Models and Architectures for Computer Network Security (MMM-ACNS'07), Sep 2007, Saint Petersburg, Russia. pp.307--321. ⟨inria-00363029⟩
201 Consultations
73 Téléchargements
