Featured-Based Vector Simulation of Water Waves - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2009
We present a feature-based vector simulation approach for simulating local wave phenomena which often appear in streams. By using this approach, we simulate the wave pattern in front of an obstacle in a flow. Based on laws in hydrodynamics, we present an efficient geometric construction method which can generate and animate the vector features of the target wave phenomenon. From the vector information, we are able to build feature aligned mesh for capturing the high-resolution details of the local waves. The results show that our approach is suitable for real-time applications. The approach also allows users to intuitively control the animation.
RR-6855.pdf (2.06 Mo) Télécharger le fichier
inria-00363339 , version 1 (23-02-2009)
inria-00363339 , version 2 (24-02-2009)
inria-00363339 , version 3 (24-02-2009)
inria-00363339 , version 4 (28-02-2009)
  • HAL Id : inria-00363339 , version 1
Qizhi Yu, Nathalie Praizelin, Frank Rochet, Fabrice Neyret. Featured-Based Vector Simulation of Water Waves. [Research Report] 2009. ⟨inria-00363339v1⟩
412 Consultations
392 Téléchargements
