Handling Spatial Relations in Logical Concept Analysis To Explore Geographical Data - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
Olivier Bedel
  • Fonction : Auteur
  • PersonId : 844265
Olivier Ridoux
Because of the expansion of geo-positioning tools and the democratization of geographical information, the amount of geo-localized data that is available around the world keeps increasing. So, the ability to efficiently retrieve informations in function of their geographical facet is an important issue. In addition to individual properties such as position and shape, spatial relations between objects are an important criteria for selecting and reaching objects of interest: e.g., given a set of touristic points, selecting those having a nearby hotel or reaching the nearby hotels. In this paper, we propose Logical Concept Analysis (LCA) and its handling of relations for representing and reasoning on various kinds of spatial relations: e.g., Euclidean distance, topological relations. Furthermore, we present an original way of navigating in geolocalized data, and compare the benefits of our approach with traditional Geographical Information Systems (GIS).
Autre [cs.OH]
icfca2008-bedel.pdf (294.02 Ko) Télécharger le fichier
inria-00363592 , version 1 (23-02-2009)
  • HAL Id : inria-00363592 , version 1
Olivier Bedel, Sébastien Ferré, Olivier Ridoux. Handling Spatial Relations in Logical Concept Analysis To Explore Geographical Data. Int. Conf. Formal Concept Analysis, 2008, Montreal, Canada. pp.241--257. ⟨inria-00363592⟩
125 Consultations
167 Téléchargements
