Integral sliding mode control of an extended Heisenberg system - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IET Control Theory and Applications Année : 2009
This paper deals with the practical robust stabilization and tracking problems of the perturbed multidimensional Heisenberg system with some additional integrators in the control input path. This objective is achieved by the use of variable structure control laws with an integral augmented sliding variable. This note shows how to select the integral sliding surface in such a way that the practical stabilization of the extended Heisenberg system is achieved in spite of the uncertainties and without loss of controllability. Experimental results on a wheeled mobile robot show the performance of the proposed controller for the practical stabilization and tracking problems.
Automatique
heisenbergcta_revised.pdf (542.28 Ko) Télécharger le fichier
inria-00366042 , version 1 (05-03-2009)
Michael Defoort, Thierry Floquet, Wilfrid Perruquetti, Serguey Drakunov. Integral sliding mode control of an extended Heisenberg system. IET Control Theory and Applications, 2009, 3 (10), pp.1409-1424. ⟨10.1049/iet-cta.2007.0480⟩. ⟨inria-00366042⟩
225 Consultations
628 Téléchargements
