Markov-Modulated Stochastic Recursive Equations with Applications to Delay-Tolerant Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2009
Dieter Fiems
  • Fonction : Auteur
  • PersonId : 858615
We investigate Markov-modulated stochastic recursive equations. This class includes multi-type branching processes with immigration as well as linear stochastic equations. Conditions are established for the existence of a stationary solution and expressions for the first two moments of this solution are found. Furthermore, the transient characteristics of the stochastic recursion are investigated: we obtain the first two moments of the transient solution as well. Finally, to illustrate our approach, the results are applied to the performance evaluation of packet forwarding in delay-tolerant mobile ad-hoc networks.
rr-6872.pdf (351.79 Ko) Télécharger le fichier
inria-00366541 , version 1 (09-03-2009)
  • HAL Id : inria-00366541 , version 1
Dieter Fiems, Eitan Altman. Markov-Modulated Stochastic Recursive Equations with Applications to Delay-Tolerant Networks. [Research Report] RR-6872, INRIA. 2009. ⟨inria-00366541⟩
104 Consultations
156 Téléchargements
