Dynamic Task and Data Placement over NUMA Architectures: an OpenMP Runtime Perspective - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
Exploiting the full computational power of current hierarchical multiprocessor machines requires a very careful distribution of threads and data among the underlying non-uniform architecture so as to avoid memory access penalties. Directive-based programming languages such as OpenMP provide programmers with an easy way to structure the parallelism of their application and to transmit this information to the runtime system. Our runtime, which is based on a multi-level thread scheduler combined with a NUMA-aware memory manager, converts this information into ``scheduling hints'' to solve thread/memory affinity issues. It enables dynamic load distribution guided by application structure and hardware topology, thus helping to achieve performance portability. First experiments show that mixed solutions (migrating threads and data) outperform Next-touch-based data distribution policies and open possibilities for new optimizations.
cameraReadyVersion.pdf (96.02 Ko) Télécharger le fichier
inria-00367570 , version 1 (11-03-2009)
François Broquedis, Nathalie Furmento, Brice Goglin, Raymond Namyst, Pierre-André Wacrenier. Dynamic Task and Data Placement over NUMA Architectures: an OpenMP Runtime Perspective. International Workshop on OpenMP (IWOMP), Jun 2009, Dresden, Germany. ⟨10.1007/978-3-642-02303-3_7⟩. ⟨inria-00367570⟩
220 Consultations
740 Téléchargements
