An upper bound on the estimation error of the sparsest solution of underdetermined linear systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
Let A be an n X m matrix with m > n, and suppose the underdetermined linear system As = x admits a unique sparse solution s0 (i.e. it has a solution s0 for which ks0k0 < 1 2 spark(A)). Suppose that we have somehow a solution (sparse or non-sparse) ^s of this system as an estimation of the true sparsest solution s0. Is it possible to construct an upper bound on the estimation error k^s - s0k2 without knowing s0? The answer is positive, and in this paper we construct such a bound which, in the case A has Unique Representation Property (URP), depends on the smallest singular value of all n X n submatrices of A.
63.pdf (221.8 Ko) Télécharger le fichier
inria-00369545 , version 1 (20-03-2009)
  • HAL Id : inria-00369545 , version 1
Massoud Babaie-Zadeh, G. Hosein Mohimani, Christian Jutten. An upper bound on the estimation error of the sparsest solution of underdetermined linear systems. SPARS'09 - Signal Processing with Adaptive Sparse Structured Representations, Inria Rennes - Bretagne Atlantique, Apr 2009, Saint Malo, France. ⟨inria-00369545⟩
233 Consultations
189 Téléchargements
