BM3D Image Denoising with Shape-Adaptive Principal Component Analysis - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
Kostadin Dabov
  • Fonction : Auteur
  • PersonId : 858950
Alessandro Foi
  • Fonction : Auteur
  • PersonId : 858951
Karen Egiazarian
  • Fonction : Auteur
  • PersonId : 858953
We propose an image denoising method that ex- ploits nonlocal image modeling, principal component analysis (PCA), and local shape-adaptive anisotropic estimation. The nonlocal modeling is exploited by grouping similar image patches in 3-D groups. The denoising is performed by shrinkage of the spectrum of a 3-D transform applied on such groups. The effectiveness of the shrinkage depends on the ability of the transform to sparsely represent the true-image data, thus separating it from the noise. We propose to improve the sparsity in two aspects. First, we employ image patches (neighborhoods) which can have data-adaptive shape. Second, we propose PCA on these adaptive-shape neighborhoods as part of the employed 3-D transform. The PCA bases are obtained by eigenvalue decompo- sition of empirical second-moment matrices that are estimated from groups of similar adaptive-shape neighborhoods. We show that the proposed method is competitive and outperforms some of the current best denoising methods, especially in preserving image details and introducing very few artifacts.
33.pdf (461.12 Ko) Télécharger le fichier
inria-00369582 , version 1 (20-03-2009)
  • HAL Id : inria-00369582 , version 1
Kostadin Dabov, Alessandro Foi, Vladimir Katkovnik, Karen Egiazarian. BM3D Image Denoising with Shape-Adaptive Principal Component Analysis. SPARS'09 - Signal Processing with Adaptive Sparse Structured Representations, Inria Rennes - Bretagne Atlantique, Apr 2009, Saint Malo, France. ⟨inria-00369582⟩
Collections
SPARS09
3537 Consultations
4655 Téléchargements
