On the parallel speed-up of Estimation of Multivariate Normal Algorithm and Evolution Strategies - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
Motivated by parallel optimization, we experiment EDA-like adaptation-rules in the case of $\lambda$ large. The rule we use, essentially based on estimation of multivariate normal algorithm, is (i) compliant with all families of distributions for which a density estimation algorithm exists (ii) simple (iii) parameter-free (iv) better than current rules in this framework of $\lambda$ large. The speed-up as a function of $\lambda$ is consistent with theoretical bounds.
lambdaLarge.pdf (185.62 Ko) Télécharger le fichier
inria-00369781 , version 1 (21-03-2009)
  • HAL Id : inria-00369781 , version 1
Fabien Teytaud, Olivier Teytaud. On the parallel speed-up of Estimation of Multivariate Normal Algorithm and Evolution Strategies. EvoNum (evostar workshop), 2009, Tuebingen, Germany. ⟨inria-00369781⟩
251 Consultations
246 Téléchargements
