s'authentifier
version française rss feed
inria-00369787, version 1
Upper Confidence Trees and Billiards for Optimal Active Learning
Philippe Rolet () 12, Michèle Sebag () 12, Olivier Teytaud () 12
CAP09 (2009)
Résumé : This paper focuses on Active Learning (AL) with bounded compu- tational resources. AL is formalized as a finite horizon Reinforcement Learning problem, and tackled as a single-player game. An approximate optimal AL strat- egy based on tree-structured multi-armed bandit algorithms and billiard-based sampling is presented together with a proof of principle of the approach.
  • Domaine : Mathématiques/Optimisation et contrôle
  • inria-00369787, version 1
  • oai:hal.inria.fr:inria-00369787
  • Contributeur :
  • Soumis le : Samedi 21 Mars 2009, 09:58:28
  • Dernière modification le : Lundi 23 Mars 2009, 14:51:47
tous les articles de la base du CCSd...
