Upper Confidence Trees and Billiards for Optimal Active Learning - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
This paper focuses on Active Learning (AL) with bounded compu- tational resources. AL is formalized as a finite horizon Reinforcement Learning problem, and tackled as a single-player game. An approximate optimal AL strat- egy based on tree-structured multi-armed bandit algorithms and billiard-based sampling is presented together with a proof of principle of the approach.
capfinal.pdf (175.39 Ko) Télécharger le fichier
inria-00369787 , version 1 (21-03-2009)
  • HAL Id : inria-00369787 , version 1
Philippe Rolet, Michèle Sebag, Olivier Teytaud. Upper Confidence Trees and Billiards for Optimal Active Learning. CAP09, 2009, Hammamet, Tunisie, Tunisia. ⟨inria-00369787⟩
203 Consultations
452 Téléchargements
