Event-based vs. Time-Triggered Communications with UML Marte - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
In the real-time and embedded domain, systems tend to combine periodic and aperiodic computations. This leads to mixing event-based with time-triggered communications with their pros and cons. Then, modeling standards of the domain must provide mechanisms to support both kinds whereas historically they pertain to different communities: asynchronous and synchronous designers. In this paper, we compare the expressiveness of two standards of the domain (AADL and MARTE) to model these two kinds of communications. Specifically, we focus on the Time facilities of MARTE and on AADL models amenable to end-to-end flow latency analyses.
fdl08.pdf (112.98 Ko) Télécharger le fichier
inria-00371392 , version 1 (27-03-2009)
Frédéric Mallet, Robert de Simone, Laurent Rioux. Event-based vs. Time-Triggered Communications with UML Marte. Forum on specification, verification & Design Languages (FDL'08), ECSI, Sep 2008, Stuttgart, Germany. pp.154-159, ⟨10.1109/FDL.2008.4641438⟩. ⟨inria-00371392⟩
152 Consultations
931 Téléchargements
