Percolation and Connectivity in AB Random Geometric Graphs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2009
D. Yogeshwaran
  • Fonction : Auteur
  • PersonId : 849793
We study a generalization to the continuum of the $AB$ percolation model on discrete lattices. Let $\Pl,\Pm$ be independent Poisson point processes in $\mR^d$, $d \geq 2,$ of intensities $\lambda, \mu$ respectively. The $AB$ random geometric graph $G(\lam, \mu, r)$ is a graph whose vertex set is $\Pl$ with edges between any two points $X_i, X_j \in \Pl$ provided there exists a $Y \in \Pm$ such that $|X_k - Y| \leq r$, $k=i, j$. We investigate percolation and connectivity in $AB$ random geometric graphs.
AB-RGG_mar16_09.pdf (225.01 Ko) Télécharger le fichier
inria-00372331 , version 1 (01-04-2009)
inria-00372331 , version 2 (02-04-2009)
inria-00372331 , version 3 (23-01-2010)
  • HAL Id : inria-00372331 , version 2
  • ARXIV : 0904.0223
Srikanth K. Iyer, D. Yogeshwaran. Percolation and Connectivity in AB Random Geometric Graphs. [Research Report] 2009. ⟨inria-00372331v2⟩
113 Consultations
313 Téléchargements
